- Sep 10, 2016
Hey guys, I recently put together a system and have begun overclocking it. My cpu is a bit of a dud (i5 3570k) which maxes out at 4.4ghz at 1.32V aida64 11.5 hours stable. My r9 290 runs 1107/1400 +25mv folding@home stable.
Before I got my cpu cooler and video card I lightly played with my ram 2x8gb corsair vengeance 1600mhz and Ive had it running at 2000mhz 9-9-9-24 at 1.5v for the past few weeks completely stable. Anyways I began pushing the ram to test its limits today, first I set the voltage to 1.6v, then tried 2200mhz and passed 3 passes of memtest86, then I tried 2400mhz and it wouldnt post, I loosened the timing to 10-10-10-26 and I was able to run 1 pass of memtest86 without errors so I tried 2600mhz, and also got it to run 1 pass. I then just decided to try and test its limits at these timings and I tried 3000mhz where it wouldnt post. So I tried upping the voltage to 1.65v and it still didnt post. So I tried 2800mhz with no post, then 2666mhz with no post. I then dropped the voltage back down to 1.6v and I was going to do further testing at 2600mhz and to my surprise it wouldnt post, so I tried 2400mhz with no post. I then dropped the timing back to 9-9-9-24, the voltage to 1.5v and set it to 2000mhz and it still wouldnt post. At stock voltage and stock timings it will boot at 1600mhz. Did I just gimp my ram? I was surprised how well my sticks were doing as most reviews I read on the set couldnt get it to run much above 2000mhz with loose timings and high voltage. I thought 1.65V was fairly safe for short term testing? Anyone got any ideas? Most of my voltage and bios settings are on auto, is it possible to the motherboard has changed one of the settings on its own which is causing the instabilities?
