- May 6, 2003
- Buried in UPS packages
Is it only the number of PCI slots and size?
Cjwinnit said:The sizes are the main factor here (apologies for the pun ). It doesn't really have much to do with the number of PCI slots, it's just easier to put more PCI slots on a bigger mobo.
why? there are now fully-featured nvorce2 M-atx boards. what pci cards do you nedd when you have the lot on-board?rdy2rave said:If you're building a pc go with ATX rather than microATX. You will thank me later.
Quite honestly, i'd gladly drop the voltage options for a m-atx rig of that spec.Features-wise, this board has some pretty nice features including 6 Channel audio, USB 2.0, AGP 8x, Dual Channel DDR333 support, integrated GF4 MX video, Dual Monitor Support but no TV out. There is also a BIOS that provides basic oc features like FSB and RAM timings adjustments. There are no voltage and multiplier controls in the BIOS
james.miller said:if you think about it, it has everything to do with it. m-atx has a defined size, which limits the number of slots you can use since going beyond that would mean you no longer have an m-atx board (becuase it is too big)
Cjwinnit said:
True, but the formfactors are defined by the sizes of the motherboards, not from how many PCI slots are on it. They could have been sneaky and put a few CNR, AMR slots there.
rdy2rave said:What about the PSU in a micro-atx case? It's not like they can fit full-size units in there. Meaning you have a less stable ps that might have problems powering all your expensive micro-atx gear.
larva said:
Bingo! We have a winner. That is the problem with micro ATX, the power supply. They simply aren't large enough to deal with the combined output and thermal stresses placed upon them. If you have a micro case that takes a full size power supply (and they do exist, I have one in the basement), micro is great. But 99% of all micro cases accept only micro supplies, and this eliminates any of the truly capable power supplies on the market from consideration.
