Just installed my new XSPC Rasa RX240-kit.
Mounted the radiator at the top of my cabinet, installed the 2 fans following the kit under the radiator pushing air from inside the cabinet through the radiator and out of the cabinet.
The fans installed from the kit are:
- 120mm
- 1650RPM
- Airflow 65.2 CFM
- Static Air Pressure 1.8 mmAq
Thing I'm wondering about is installing another pair of fans wich I have, on top of the radiator so I get a push/pull-config.
They are:
Corsair SP120
- 120mm
- 1450RPM
- Airflow 37.95 CFM
- Static Air Pressure 1.29mm
Will this help my performance ? Or does the different stats on the fans just mess it all up?
Edit:
Got another pair of fans I could put on top there.
Those are:
NZXT FZ140
- 140mm
- 1000RPM
- Airflow 83,6 CFM
- Airpressure 0.81 mmH₂O
Would these do any better ?
- 120mm
- 1650RPM
- Airflow 65.2 CFM
They are:
Corsair SP120
- 120mm
- 1450RPM
- Airflow 37.95 CFM
Edit:
Those are:
NZXT FZ140
- 140mm
- 1000RPM
- Airflow 83,6 CFM
