hi all. apologies if this is in the wrong place on the forum but i had a question about a build im working on.
im looking to set up a combo air/water cooler for my cpu. basically the idea is to take a heat sink with multiple heat pipes, cut one of the pipes open to pump water through and leave the rest as is. the idea is that the water will cool the bulk of the cpu heat and the remaining (intact) heat pipes and fan will take care of the rest and more importantly serve as a backup should my pump fail. ive set up a similar system before only there i used all of the heat sink's pipes to pump water. i had a pump fail once and the cpu temps skyrocketed for a few days before i noticed something was wrong. my system will run 24/7 at 100% load (folding at home, etc.) in an office so my main reasoning for this type of setup would be for redundancy and noise reduction.
my question is that since this will probably cause uneven cooling on the heat sink base my cpu die will likely have uneven core temps. how big of an issue is this? im thinking the area of the heat sink base that has the water pipe will be much colder than the intact heat pipes. even if i line up a heat pipe so that its right over the cpu die i doubt ill be lucky enough to find a heat sink that has one heat pipe covering 100% of the cpu die, so some areas are going to be cold while others hotter. hope that makes sense. any help you guys can offer is greatly appreciated.
cheers
cheers
