Hi!
I'm interested in adding some safety features to my controller which includes both PWM controller circuits as well as standard potentiometer control.
Fan starter circuit:
For a pot controlled fan I guess it's easy. You just connect a capacitor in parallel.
But may a basic 555 circuit be retrofitted with a capacitor on the PWM out to obtain a 'starter' feature? What would be the wiring and capacitance? Obviously it can't be calculated using resistance of the fan itself. I don't even know whether it's a correct approach so please excuse my ignorance.
Any alternative solutions for kickstarting a PWM fan?
Indicators:
Any other ideas apart from kickstarting the fans? What would be the wiring for a LED that would light up if a fan rotates BELOW certain RPM. As an electronoob I don't see any simple way to achieve this.
I'd appreciate any suggestions.
Motherboard:
My controller feeds RPM signal to motherboard of my PC. Using the selector switch I've fitted I can select which fan feeds the signal. I've just realized I can connect an extra RPM signal wire to the second fan header of my motherboard and use the 'fan halt' alarm feature found in the BIOS.
Indicators:
Motherboard:
