- Apr 26, 2009
- Athens, Georgia
after having some horrible experience with a am2+ board not liking any memory I used in it, I decided to purchase a different MB for my phenom II, this time I was going the AM3 and DDR3 route. At the store where I purchased the memory the only thing with tight timings and reasonable speed was a Set of Patriot Viper 1600mhz (7-7-7-20) 1.9v. I played around for the last 2 days trying to find top overclock on cpu and memory and could only get memory to do specified timings and speed with 1.97v. Unsure of what tolerance the IC in this memory had to higher voltage, I promptly joined patriots forums and posted The question "What is highest Volts that this kit can do safely for long term" and after given the usual loosen timings crap I asked again. the answer shocked me, I was told 1.92, and the reason was more or less that I would fry the IMC if I used higher.
Knowing that I did'nt want to cook my phenom II, I decided just to return the memory to the retail store. A brief pass by the tech department somewhat (as in the tech said Patriot had good reasoning but he in fact had no proof only that I7 dont work well with higher voltage ddr3) confirmed that the higher voltage is probably unsafe. So please answer me something anyone who really knows about phenom II's and memory, WTF is Patriot doing telling me that basically 1.92+ will cook IMC (and I know some boards overvolt) and marketing a kit http://www.patriotmemory.com/products/detailp.jsp?prodline=5&catid=52&prodgroupid=120&id=858&type=1 for am3 processors (I know it has to be am3 because no other AMD Black edition will work with ddr3) that needs 1.9v to do specified timings if slightly higher voltage will cook the IMC.
Also I know OCZ sells a 1600mhz kit with 7-7-7-24 timings and 1.65v but it is out of stock at the egg and the other places that carry it dont exactly have the best reputation per customer complaints I read.
