- May 1, 2012
- Amman, Jordan
Guyz i'm having a bit of confusion about the Gigabyte Superp 720w 80+ PSU
I'm having no problems till now but i just installed the Gigabyte gtx 660ti oc graphic card in my system and i'm going for the 2nd one in Sli,the card is rated at 225w at full load with no overclock.Do i have to change the PSU for this system now or when i upgrade to Sli?
Specs:
Cpu: 2600k @ 4.2
Ram:Kingstone 1600 9,9,9,24
M.B:Gigabyte z68xp-ud3r
Cpu cooler: CM v10 wich may take 70w at full load for the TEC.
Drives OCZ aguility 3 60gb ssd,Sandisk sata 3 64gb SSD,2X WD Drives.
7 120mm system fans
my last question is that if i disconnected the Tec will the sli work??
my calculations 100 + 225 + 225 = 550w
Specs:
Cpu: 2600k @ 4.2
7 120mm system fans
