Completed my first custom loop couple weeks ago and just want to make sure my loop is OK. I had to mount the res on the opposite side of the case because i dint have a fan mount for the res and the lian li O11 dynamic has no mount holes. Temps at idle for cpu are 25-28C and GPU 24-27C. During Prime95 smallFFT CPU temps are between 75-80C and during long gaming sessions GPU reaches 50C which i think is kind of high. Can the inlet and outlet be on the same side for the GPU or is that causing flow issues? Water temp is between 23-26c at idle and during long gaming sessions it will see 28-31c.
RES > PUMP > RAD > GPU > CPU > RAD <
Specs:
i9-9900k (oc'd to 5.0Ghz all cores 1.295 vcore -2 AVX ffset)
RTX 2080 (+65 core +1000 memory)
Specs:
