- Nov 12, 2002
- Rootstown, OH
Thanks for your comments. A few related (and unrelated) thoughts:
First, most organization have some very good people (cool folks) in them. And that will certainly be true of OCZ.
Second, it is a little beyond "poor judgment" nearer to dishonest as far as the product they delivered versus their advertised specs. I guess the FTC could get involved if someone bothered to fill a complaint but I doubt it.
Third, if they had stepped up to the plate from day one to address the problem as Intel and the mobo makers for the Sandybridge quickly did, while there might have been some grumbling most would have worked through the issues. However that hasn't been the case, instead OCZ has retreated to their current position -- the one they should have taken to start with.
I agree for the most part. I guess I discount published specs universally and haven't thought much about that, but you are right there that it can be misleading. From the specification tab here:
50-240GB Max Performance
Max Read: up to 285MB/s
Max Write: up to 275MB/s
Sustained Write: up to 250MB/s
Random Write 4KB (Aligned): 50,000 IOPS
The "up to" stats don't have any semblance of accuracy in regards to the actual performance for this revision - and putting it under the same previously STRONG product line doesn't help.
Then again, stuff like that is the reason sites like ours have flourished. It takes a lot of insight and sifting to separate the marketing from the exact performance numbers.
