- Apr 5, 2012
- Malaysia, South East Asia.
- Thread Starter
- #21
The thing is that it is quite hard to have 60+ Amp on one single rail (not a lot would support it ^^'). It is possible to use multiple rail in order to lower the requirement on each rail.
The seasonic X-760 for instance is a 12V single-rail PSU.
This one is multi-rail:
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story2&reid=327
The issue with the multi-rail is that you can't simply say "well, if I can do a single rail PSU that supports 60 Amp, I have to be able to build a 4 rail PSU with each rail supporting 60 Amp to build a monster PSU supporting 240 Amp muahahahaha"
It just doesn't work like that. If you plan to build a PSU, single or multi rail, the max power is determined by a lot of parameters outside the number of rails.
So, with a limited max power, you have to split it in several rails. You also have a limited current on each rail... so limited sometimes that it isn't enough to feed a GPU
The Inwin that I've linked you would have trouble running an OCd GTX580 for example
The key for the customer stays the same: always check the current for the 12V rail(s) and see if it matches with the components
WAO...that's 25 amp on the rail , it's still lacking ?? The GTX 580 is so power consuming ?? Because as i said ,i saw a vid he said usually 18 - 20 amp will do fine...but....uh he did mention something like if you don't go crazy like Xfire / SLI , heavily OC , Multi Rail be fine , if you looking to do heavy OC and such , it's better off with a Single Rail with high Amp , but usually those are over 1000W PSU....
Here , this is the vid i learn from , though looking back at it again...this is during 2008....lol ! Maybe things changed plenty since then...
