Is a bulging capacitor top an automatic positive indication of the "capacitor plague?"
It's usually a sign of the plague, but sometimes if it's just one otherwise good quality cap, it indicates that a particular area of the board is getting too hot.
But that bulging one on your board looks like it might be a Chemicon KZG series, which is known to have a lot of failures. If that's the case, you should probably replace all the ones of that type. It looks like there's only four of 'em, so it wouldn't be a big project.
LOL, what is capacitor plague? If one cap exlpodes its going to affect the others??? I have never heard that term before!
So a capacitor goes bad and instatly goes back to caps made in 99-07? I guess that board was made around that time...
Thanks for the info!
Only if it's a Dell.Is a bulging capacitor top an automatic positive indication of the "capacitor plague?"
Good luck finding a cheap CPU-mobo combo at Fry's any more because some employees have said that the company has decided to discontinue them, and ads in the past few weeks have featured none of them. Worse, they're advertising CPUs alone, at the same prices as the combos with the same CPUs. And even if you do find cheap combo, unless it includes a Gigabyte mobo, it will probably still have some bad caps on it.I don't know that I'll replace the caps, might be less trouble/effort to just replace it with a cheap Fry's combo in a couple of months on BF.
