Some of the links don't work so I'll have to just guess:
Depending on the thickness of the rad, a 360 will fit either in the front (with modifications) or the top. Installing the rad in the top, the rad will have to come up from the bottom inside the case and the fans will have to from the top down so it'll be sandwiched. I doubt you'll get push/pull. In the front you'll have to remove the 5.25 drive bay and cut/modify the power supply's cover/shroud. Again very doubtful to get push/pull because of that.
The EK Supremacy is an excellent block. I don't know what tubing you'll be using and from what I can tell you're going with compression fittings. The pump/res combo is great.
My suggestion is to look around the net for pictures of your case being watercooled to get an idea what you're up against.
