- Mar 13, 2006
Assuming that you have a 64 bit OS to be able to address more than 4GB? Also assuming that you are running programs which will GLADLY use all available RAM? Yes there is an advantage.
I can run more VMs with usable levels of RAM if I have 16GB vs. having only 8GB.
CAD, Photoshop, and many other programs will GLADLY use all of the RAM you will provide.
I have seen EXCEL files (this is back in the XP64 timeframe) that rival DWG files and those were crashing lower power systems (had to open them up on a workstation and split the file up into multiple ones.)
RAMDisk is also another "option" that will gladly utilize everything you provide it.
Ram SPEED is not as noticeable for 99.9% of people (unless you are using benchmarks or LOOKING for it) vs. CPU speed and/or SSD vs. HDD.
Most all of my NON servers have the following specs:
Quad Core CPU (disregard Speed, HT, etc.)
SSD (OS and some programs) + HDD (Data Store and all other programs)
8+Gb Ram (disregard speed, or whether DDR2 or 3)
Win7x64
If I drop to 1gb of Ram, there will be a noticeable and obvious impact on performance.
If I drop to 4gb of Ram, there is a noticeable difference but it is minimal if not absolutely trivial.
Processor wise. Disabling cores results in performance impacts very similar to RAM but even longer in timeframe. THIS is only affected and apparent by programs which are Multithreaded and then only to the point that they are capable of using.
Taken directly from Microsoft:
PCs with multi-core processors:
Windows 7 was designed to work with today's multi-core processors. All 32-bit versions of Windows 7 can support up to 32 processor cores, while 64‑bit versions can support up to 256 processor cores.
PCs with multiple processors (CPUs):
Commercial servers, workstations, and other high-end PCs may have more than one physical processor. Windows 7 Professional, Enterprise, and Ultimate allow for two physical processors, providing the best performance on these computers. Windows 7 Starter, Home Basic, and Home Premium will recognize only one physical processor.
VersionLimit on X86Limit on X64 Windows 8 Enterprise 4 GB
512 GB
Windows 8 Professional 4 GB
512 GB
Windows 8 4 GB
128 GB
Physical Memory Limits: Windows Server 2012
The following table specifies the limits on physical memory for Windows Server 2012. Windows Server 2012 is available only in X64 editions.
VersionLimit on X64 Windows Server 2012 Datacenter 4 TB
Windows Server 2012 Standard 4 TB
Windows Server 2012 Essentials 64 GB
Windows Server 2012 Foundation 32 GB
Windows Storage Server 2012 Workgroup 32 GB
Windows Storage Server 2012 Standard 4 TB
Hyper-V Server 2012 4 TB
Physical Memory Limits: Windows 7
The following table specifies the limits on physical memory for Windows 7.
VersionLimit on X86Limit on X64 Windows 7 Ultimate 4 GB
192 GB
Windows 7 Enterprise 4 GB
192 GB
Windows 7 Professional 4 GB
192 GB
Windows 7 Home Premium 4 GB
16 GB
Windows 7 Home Basic 4 GB
8 GB
Windows 7 Starter 2 GB
N/A
http://msdn.microsoft.com/en-us/library/windows/desktop/aa366778(v=vs.85).aspx
Win7x64
512 GB
512 GB
Windows 8 4 GB
128 GB
192 GB
192 GB
192 GB
16 GB
8 GB
N/A
