- Dec 21, 2009
Hey everyone, it's been several years (8) since I've done a WC build, so I just wanted some advice on the best tubing, coolant, and biocide/anti-algae additives these days. Way back when, PT Nuke and silver kill coils were the way to go + distilled.
This build will be soft tubing, HardwareLabs Black Ice Black Carbon rads and EK Velocity Full Nickel (not sure why it's called that, because it appears to be nickel plated copper, but I digress). Oh, and still trying to decide on acetal or acetal + nickel, etc. for the GPU block. Does it matter?
What tubing is good these days, and what coolant/biocides do you recommend?
