Thanks for the guide. I have been looking for this information for several days.
I have a question. Last night I OC'ed my CPU to 236x17. I ran prime95 for 20 mins and played game for 3+ hours after that with no problem. However, my computer crashed during the day, and my computer can only run stable at 240x16 now. Does the weather affect overclocking?
Here is my setups http://img17.imageshack.us/img17/7476/system2z.png
@csimon
Sorry for the late reply, I have been more busy that usual.
No is the answer. The HTv has no effect on the CPUv or the CPU-NBv. But the CPU-NBv and the CPUv do play off each other, but not the way you would imagine. Raising one does not mean the other benefits. Raising the CPU-NBv can help stable an OC and sometimes help lower your CPUv. I suggest lowering your CPU-NBv since it is high. Use something like 1.25v or lower.
I just wanted to say thank you to Dolk for such an excellent guide and for taking all that time to put it together. It's brilliantly clear. Following it I was able to take my little 1100T up to a contented 4GHz in no time at all and it's happily purring along.
I've got
CPU @ 200MHz x 20, 1.4v
NB @ 2600MHz
HTT @ 2600MHz
Core temperatures seem to be floating around at 21.2C.
I haven't touched memory yet. I have Corsair Dominator CAS 8 (and some Corsair Vengeance, also CAS 8) which according to AMD Overdrive is at CAS Latency 9 if I'm reading it right, so bumping the memory up may be my next challenge. Though looking at those temperatures, I think my CPU would be happy to go higher!
Anyway, mainly just posting to say thank you! I do graphics rendering on my box, so a bump from 3.3GHz to 4.0 (and probably higher), is actually relevant and useful to me.
Cheers,
H.
Congrats, What are you cooling that cpu with? and what are the ambient temps? In most cases around 20-22c is a pretty avg home ambient. I doubt your proc is staying at that range under full load.. you should at least see a 15-20c delta under extremely optimal conditions for air or water cooling.
That sounds like a more accurate result of extended stressing of the cpu with that setup and cooler. as long as they aren't knocking on the door of 55c Your good. As far as your future memory options I can advise that rotating the cooler around and fan configuration can help fit memory in a squeeze. I have used that cooler before and ran into a similar situation.
edit:// also, don't be sad, that's a pretty respectable result
