- Dec 27, 2008
SuperNewB,
I suspect with your CPU voltage at 1.544 and only using the Coolermaster Hyper 212+ to cool it you are having temp related instability. With that amount of voltage and six cores it's going to be producing a lot of watts. What we need you to do is to open up HWMonitor on the desktop and leave it open while you run the Prime95 blend test for 20 minutes. Then post back with a pic of the HWMonitor interface. If you cannot pass the test for 20 minutes take note of what the max core temps were and the max CPU (socket) temps were right before BSOD. The CPU socket temp may be masked by a generic label like TMPINx. We need to know what your temps are like under full load.
Also, could you post CPU-z tabs: "Memory" and "SPD" along with "CPU" please?
