I have this raM: DDR3 Corsair Value CMV4GX3M2A1333C9 1333Mhz 4GB
CAS / Timings / Voltage
9 / 9-9-9-24 a 1.333MHz (a 1.066MHZ 7-7-7-20) / 1,6v
So, i should use these timings right? (9-9-9-24)
hello everybody.
id like to ask if i've done something wrong. im pretty new to oc'ing not to say a total noob
i've set the core voltage to 1,40V in bios but its at what u can see on the picture. no idea why
my question is: could it be my NB-Frequency and HT-link is too fast? should i lower it a bit?
HT-Link is at 1600mhz and NB thingy is 267 * 9
here the picture: http://250kb.de/oW1g5u8
Hi,
Thank you for your manual its great.
Just want to ask you.I have AMD Phenom2 x3 BE. I can go to 4ghz no problem.My problem is
I cant unlock fourth core.Anytime if i try to unlock fourth core Windows 7 64 crashes in louding.
I bought recently new memory OCZ Reaper Edition DDR2RAM CL5-5-5 bcs I thought it maybe the problem but not still the same
if i go back to 3 core tehre is no problem and i can do ovecloking very well.
CAn you help me pls to open all cores?thank You PAvel
Is there someway to get a 965 to 4.0 or around 4 without raising the voltage of the cpu?
No, almost any overclock needs a voltage bump.
Will an overclock be more stable by raising the FSB than simply turning up the multiplier?
Hey man i registered just to say thanks for these EXACT SETTINGSMost the folks here (including me) are going to nag you and tell you off for using AMD Overdrive, with good reason.
Is highly recommendable to use directly the BIOS for proper overclocking.
You can try this settings as a starting point, though I can't guarantee you they will work perfectly:
CPU: 3.8GHz 1.350v/1.375v
CPU-NB: 2400MHz 1.200v/1.225v
HT Link: 2000Mhz (Default)
RAM: 1600MHz 9-9-9-24-1T (the voltage should be 1.5v or whatever your ram is meant to run at)
Then run Prime95 on blend atleast 1 hour, the more the better though.
