- May 27, 2002
- Ohio
Ok, a friend of mine is upgrading his PC.
we are looking for suggestions, to possibly make this better. mind you, he has MAXED OUT his budget. We have already factored in S&H, which pretty much max's his budget of about $1100.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103191 - AMD AM2 6400+
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130305 - EVGA Nvidia 8800 SSC.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131011 - ASUS M2N32-SLI Deluxe. ( mind you, took us HOURS to find exactly what he needed. it NEEDS at least 1 PATA, and 2 PCI.
http://shop4.outpost.com/product/5439699 - 4GB PC6400 DUAL C4 OCZ RAM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106070 - a SATA DVD burner. Buying this stops him from NEEDING 2 PATA's on the motherboard.
http://www.heatsinkfactory.com/thermalright-ultra-120-extreme-cpu-cooler-p-16580.html - the Thermalright Ultra-120 Extreme.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811103010 - And the case. He likes the 2 big 250mm fans.
he already has a PSU that can handle the system. though, he'd LIKE to be able to get a better one...but it won't fit in the budget. But, anyone have any suggestions for a good, but not too expensive PSU that may work?
Also, he is NOT going to go intel for anything. He's a AMD fanboy. so the mere suggestion is not even worth the time it will take to type it.
he's not much of an overclocker either. he doesn't have a problem OC'ing a CPU by a few hundred Mhz. but other than that, he's not much of a OC'er. hence why he picked out the 6400+
Sooo...Any suggestions? any comments? concerns? Anything in this list that could be killed off, and replaced with something that is equal in performance, or better for the same price or cheaper?
