- Aug 18, 2013
Hi fella pc users!
i currently started playing Final Fantasy 14 and after 2 minutes of game play my fps drops to 5 fps (from 90) and its unplayable(it goes from 90 to5 and then shots back up to 90 after so many seconds). so i chose to ignore it since the game is in beta and i thought it was some server lagg or whatever. i t hapend again and i then took to my trusted friend "CPU_Z" to chek what was going on. with the game open and while standing still the Multiplier and the core speed/voltage drops like mad for 20 seconds and then pop back up. its not only in this game, this happends when im watching streams or playing other game aswell.
Before drop:
core volt:1.380
core speed: 4118
Multi: 20.5
After drop
core volt: 0.800
core speed: 1.600
Multi: 7 or 8 (cant remeber)
Rig
Mobo: gigabyte 970a DS3
Ram 8gb
Hdd: 500gb not near full (formated pc yesterday to avoid stuff liek this)
GFX: GTX 660
CPU: AMD FX 8350 8 core 4.0ghz
650W PSU
what ive tested
*Change power setting to Max performance
*changed the resolution in game - max or low nothing matters
*turned on and off vertical sync
*turned off cool and quite
*turned off C1E (or whatever its called in bios)
*checked the temps - under load(50% while gaming) 55-60 celcius
*reformated pc
*reinstalled the game
*reinstalled drivers to gfx card
*recently changed from stock fan to a third party: https://www.inet.se/files/img/max/5322078_5.png
(can i have put too much paste on the cooler? i put a VERY thin layer on the cooler and thicker layer on the cpu itself. not ALOT but there is a layer there.)
Where can i go from here?
should i reformate again and pick apart the whole pc and put it back together again ? it doesnt seen that the cpu is over heating since it stays around 55-60 degrees.
Before drop:
core volt:1.380
core speed: 4118
Multi: 20.5
After drop
core volt: 0.800
core speed: 1.600
Rig
Ram 8gb
GFX: GTX 660
650W PSU
what ive tested
*reformated pc
