- Aug 18, 2013
- Thread Starter
- #41
1. Look for Quick Links above right and go to EDIT SIgnature and make a signature like you see at the bottom of my posts so that we can tell what the heck is in play now.
2. Are we to assume you are using the cpu cooler that came in the box with the FX-8350 or did I miss something? A good reason to have a signature.
3. Do you plan to overclock the cpu any and thus for 'certain' need to get a much better cooler for that 8 core cpu?
4. Cannot remember other than you referrring to gaming as what you do with the computer? Cpu Mhz is king. You could even disable a couple of "modules" so the cpu could run faster without so much heat.
5. This is n0t the weak 970 mobo without enough VRM phases. It would be the least of the boards that I would choose to use. it is not the same caliber as the Asrock 990FX EXT9 board but should do okay up to about 4.4/4.5Ghz if you have enough cpu and case cooling. The Asrock 990FX EXT9 board by all reports is a very good motherboard for "really" pushing an 8 core FX processor.
Asrock AMD Motherboard : ASRock 990FX Extreme4
ASRock 990FX Extreme4. Description; CHIPSET: NORTH BRIDGE : AMD 990FX ... - Digi Power Design - Advanced V8 + 2 Power Phase Design - Supports CPU up to 140W TDP.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157266
There has been so much turmoil with the latest Gigabyte 990FX/X in UD3 and UD5 versions that I just cannot seem to make myself suggest them.
RGone...
everything u asked there has been answered mate. i even have all your queastions in my first post (except the overclocking part). ill write them again.
*2 - using a third party cooler. link is in my post.
*3 - not planing to overclock, might tweak it alittle but i wont push it for sure.
*4 - only gaming, nothing else
*5 - cant afford the motherboard u are talking aobut. the one i linked is the budget im looking for.
