Hello, as you can see its the first post and i am making it to ask something.
This is my first overclock i have read as much as i can on how (Here, Tom's Hardware, random people with same Motherboard/CPU and why but:
I certainly have an i7 2600K at 4.3GHz, at 1.255V (Motherboard seems to give 1.272 during idle though and 1.312 during Intel Burn Test) with an MSI P67A-GD65, i am not using the 1.19 BIOS or the 4.3 (If someone knows i would love to know if i should install the 4.3, MSI says i shouldnt since its for Ivy, others report its awesome, others report problems, i simply dont know!) since i had an issue with cold restart during boot because of some USB related issues combined with the newer BIOS (This mobo is a nightmare -.-) so i am using the 1.E versions or 1.14 as its called otherwise.
It seems to be stable, i have run Intel Burn Test at Very High and Maximum multiple times, letting it do 10 tests or 5 tests depending on how much time i have.
I have also tried 4.5GHz at 1.310V on the Motherboard, which is if i recall 1.34 on CPU-Z, and 1.38 during Intel Burn test but here is the problem, i would get BSOD of 0x124 which is not having enough Vcore as far as i have read so i kept increasing it by 0.05 as the motherboard allows till it stopped giving BSOD on the Intel Burn Test.
I cant test properly because the moment the test gets heavy 10 seconds in, the CPU downclocks at 4.3GHz and 10 seconds after at 4.2GHz, it could be temperature related since its hitting 88C on the third core while the others are at 82C since i read that some mobo's do that, but i cant find if mine does that and if its something else.
I know 88C is a bit high, i am using a Xigmatek Aegir but the idle temps are good enough for 1.344V compared to what i had for 2 years on the useless stock cooler during stock values... i am not gonna be running the PC at 100% for ages, i just play games and it wont reach that high, but my problem is that i cant test if its stable since it downclocks.
For other reasons that it would take ages to mention, mostly not wanting to waste money, i cant change my case to make the airflow better, i could reaset the Cooler with a new paste but thats about it..
Is it the heat that causes the downclocking or something on the damn MSI board that causes it?
EDIT: 5mins after i wrote this i just had an idle crush, i increase the Vcore a bit and enabled C State, now need to wait and see but i confirmed that the CPU downclocks when it reaches 85C (I change the volate to 1.270 from 1.255 so the load went to 1.336 from 1.312 and it went from 82C to 85C and it downclocked instantly), should i change the voltages to what i had and let it run the Intel Burn tests multiple times? Since it downclocks how can i know its stable? I wont even stress the CPU that much at daily use.
