Taking the pumps out of the equation, wouldn't this be a quick way to drain most of the water from your loop? What harm can it do without the pumps being sucked too?
loosen the top & bottom hoses and blow the water out.... just make sure to have a bite of pastrami sandwich between blows... refill, dont use biocide.... make sure loop is exposed to day/sunlight.... in a week or so, you can call yourself a god
PS: Pastrami is NOT crucial to create life, its just what i was having when i wrote this
Would be fine so long as the negative pressure doesn't cause your radiator to cave in... which I highly doubt it would be. But not necessary. Beneficial? Not sure.
I usually let gravity give it a go, then shake out the parts individually. Sunlight would help dry em out, or blow compressed air though. Also, I'd leave the pump hooked up. I doubt the vacuum would cause a water pump impeller to rotate...
Makes me wonder curious... I have three rads doing nothing. Should I be the canary down the mine and cap a triple 120 to see if I can make it fold with an industrial vac?
I also have an heavy duty steam cleaner... So I can experiment with killing it to remove dust bunnies too.
Whats junk to one man is anothers treasure...
Vote now!?
Dust bunnies... Check!
Steam mc clean... Check!
1000w wet 'n dry... Check!
Heh... Experiment a go go
Lets Go!
Phase one... Steam McCleaned
Dont use a brass brush head... Some paint flaked off fins. Use nylon brush
Now im going to finish my cooling coffee then look for some parts to cap the rad and have a go at collapsing it
Edit: will a thousand watts industrial vac collaps the rad?
Bet now!
Lol
If my vacs dies first will someone buy the other two rads?
They'll be like new with a steam clean.... Wear face goggles and ear defenders. Maybe gloves too... Hot potatoe hot potatoe
Sodding country... Play off due to rain will continue when this shower passes
Note: steaming had no effect on removing the ethyl glycol based coolant I used before I learned better here.
So bear in mind that dye stuffs your rads right up
+1 for distilled, biocide and/or kill coil ^_^
Capped with around 3 quaters of a meter hose inside the vacs hose... Trusty gaff tape.
Left it for three minutes until the motor was read hot from zero airflow.
After 100% fine... No collaps with 1000watts industrial vacume
Myth busted.... Crud busted!
Case closed.
It did reveal a small fracture I could never identify back in its operational days!
See the tiny hole underneath the weld for the screw plate... I could never find it while in use.
Dab of filler would sort that out
So caution with steam and vacs clean... You may remove paint to reveal floors in the welding process during production
I assure looking at the water marks this was previous damage I put down to a hose leak for a couple of years
Always double check... It used to drip once a week onto my gpu cooling block!
Note the butchered louvers was nothing to do with the steam clean... Its just a five/six year old rad... My first real rad
Well I shall try to look it up... Wickes only ever made one model. 1000watt heavy duty wet n dry vacuum picks up mortar and chunks of house brick. Fair to say if the loops open its very unlikely to collapse any rads.
First of this is the biggest hijacking I've seen of a thread in a while. I think the last time it was someone who was either a spammer or hacked account and got banned.
Create your own thread next time. Try keeping your answers to a response instead of flooding the place up.
Feel like this thread has gone to waste. Great info but you totally threw the OP out the window.
All this back and forth personal life stuff doesn't belong either. We're in the H20 thread guys. Go to the generals tab and have a fest. Common folks!
You're going to get nabbed for that comment Bobby. We don't talk like that around here. He makes a valid point about threadjacking, but, I agree that the question IS already answered: It is safe. Going off topic isn't harmful, but err... a little more on topic, and consolidated posts is recommended
