Hi, I just finished my first custom water cooling build but the drain port that i set up is not working. When the tap is opened, only the water from the Reservoir are drained out and others just stuck inside the loop. I have placed the drain port on the bottom of my loop but whey is this happening? Any suggestion so that I can clean my loop easily without taking the tubes off?
