I may be getting carried away but is it OK to run a dual reservoir/pump setup for redundancy as long as they match? I am having issues with water levels being the same height on my 250mm tubes. Would I be better to run one on my CPU and the other to my GPU. My rads are both Alphacool one is 429x60 other is 360x60. I am cooling a 1950x Threadripper and a 2080 Waterforce. Everything was great cooling everything with one pump with a smaller 420 mm rad and then I got some extra cash and purchased the 420x60 and ended up with the other pump/res I bought for my son because it wouldn't fit in his case.
