- Sep 6, 2003
I use PowerDVD 6 and it use to work fine, but now when I try to runa dvd full screen the DVD stays the same size as the window was, the rest of the screen goes black and the dvd moves to the upper left hand corner of the screen.
I have tried uninstalling and reinstalling and that does not help. I also got the ASPI layer drivers and installed those and that helped then I changed a setting and it reverted, after which I tried restoring all the settings and it still maximized to the upper left hand corner of the screen.
Windows Media Player 10 plas the DVDs full screen just fine, however I dont like using WM10 as I notice the picture is not as sharp and I dont like the controls as much
Any Suggestions?
Any Suggestions?
