- Nov 20, 2006
I have a D-Link DI-624 wireless router at home that originally was hooked up to my WinXP PC by cable. It was all working well. Moved the computer to another room and bought a DWL-G132 network adaptor and am now trying to get it to work. When I connect it all goes well either with Windows control or using the D-Link software and recognises the AP etc. You can then browse the web for all of 20secs before it wont find any more web pages or do anything. It says it is still connected but no packets are being transmitted or received. Eventually it usually disconnects and then a re-scan of wireless networks finds nothing. Starting and stopping the Windows Zero Config wervice does nothing at this stage. If you unplug the adaptor and plug it back in then you are back where you started, connection for 20secs, blah blah blah. Signal strength is about 80%. Driver is version 1.20, revison is A2 for hardware
From scouring the web this kind of thing seems to be the fault of Windows Zero Configuration thingee taking over and trying to connect to another network and knocking you off but I'm not sure of that in this case.
Things I have tried
1) The adaptor works on my laptop fine sitting at the same distance as the computer is from the router either using WZC tool or the Dlink software
2) As I said the same problem occurs when using WZC or Dlink software. Also tried the Boingo wireless connection software with the same result.
3) I am broadcasting the SSID but it makes no difference
4) I have tried turning off all security and changing channels on the router and turning of Turbo with no effect.
5) No microwave going at the time and I tried unplugging the cordles phone but neither change anything. (the laptop works fine with it under all these conditions anyway)
6) Motherboard has all the latest drivers etc
7) Windows XP has SP2 so no issue with the updates required to get it to work as several websites say.
8) I have tried various drivers from the Taiwanese and USA D-Link sites but it all does nothing different apart from a few BSODs when uninstalling, re-installing all these drivers.
9) 802.11x security thing is not ticked as several websites suggest this is a problem for lost connection
9) Have turned off Antivirus, firewall, Skype, Gmail and any other thing I can find that connects to the internet. Still the same.
It seems to me there is still some other windows program or service knocking my connection off and generally not playing nice
Thanks for your help
Things I have tried
