I got a gigabyte 945GME-DS2 and this Motherboard has NO overclocking options, is there a utility I can use, the Easytune does not have overclocking abilities!
I had this upto 2.6 GHz before on the old mobo before it stuffed out
you should really research your motherboards better before you buy.
if the mobo didn't come with a utility then you may have luck with clockgen, but really with that mobo it won't be worth it. it has a 945 chipset, so it even at default speeds (266fsb) it is already close to its limit. you may get 300fsb outta it, but even that i wouldn't count on.
