Hi peoples, new to the forum and consequently new to overclocking. Been doing alot of reading up lately on overclocking my CPU as its whats holding me back and I figure why not get the most outta my CPU before I decide if an upgrade is truely worth paying for!
My system:
Asus Rampage Formula
E8600 3.33Ghz @ 4.3ghz
Arctic Freezer Pro CPU Cooler
OCZ 4GB (2x2GB) DDR2 1066MHz/PC2-8500 Blade Memory Kit
OCZ Vertex 2 180gb SSD
MSI R5870 Lightning 1GB GDDR5
Antec Lanboy Air Case (
Overclocked settings:
FSB: 430 x 10
Vcore: 1.3625v (tried at the one below and was unstable)
Dram Volt: 2.1v
CPU PLL Voltage: 1.5 (lowest setting my mobo offers)
Now, last night I ran Prime95 like this (except pll voltage was on auto) for 1hr 17mins and no problems and then went to bed (switched it all off because I didnt like the idea of waking up dead)
Today when I got in from work, I did some tweaking around, figured I could get 4.5ghz (450fsb) out of it.. and I can and for the minute it runs the temps are fine but then I get a bsod and a reboot, same on 4.4ghz (440fsb).
I switched it back to 4.3ghz and ran it on prime 95, fine for 27minutes and then a rounding error.. argh! So I went into the bios and put pll voltage on 1.5 (i read somewhere thats a safe voltage but any higher and youll fry the chip)
I was just looking really for some help on fine tuning my system.
Currently running error free for over an hour at suitable temps:
http://img830.imageshack.us/img830/5541/prime95c.jpg
I've tried lowering the voltage but I get instability and rounding errors so I'm not sure where to go with other voltages, ideally I imagine I want to lower the voltage to the minimum (for power saving/less strain on the cpu and less heat output)
Any advices?
My system:
FSB: 430 x 10
Dram Volt: 2.1v
Any advices?
