- Jun 14, 2004
I am restoring off all of my backup dvd's. Due to a dumb boo boo on my part.
I am wanting to make the files 777 so it is easier until all the data is in place. Then I will reset the permissions as I need. I have many dupes and they are not deleting/moving easy and other fun stuff. I am doing all this via two computers. Since It gives me two more DVD drives to drop data from. 4 HD's and 3 dvd drives makes for fast work. Just hte permissions are slowing me up./ Plus Me doing it all slow like.
So I am doing this...
Pull off dvd. (one folder at a time or grups of folder, simply put. A dvd's worth.)
sudo chmod 777 /where/the/dat/is/held -R
Then I move it.
cp in/this/folder /to/the/destination_folder(each one is unique)
What I would like to to, after it is on the HD. Is to change the permissions before I move the stuff around, or afterwards. Don't matter really. Long as the end result allows me to not have the hassle of root permissions. At least until I got the data in it's place. Then I can reset the permissions as needed later on.
So how can I make this one easy command line step? Also how would I move specific multiple folders to specific destinations?
Like:
folder_1 to music on one drive and folder_ to pictures on another.. in one step? It would actually be more than two folders and multiple separate unique destinations.
Then I move it.
Like:
