So I wanna buy this MOBO: http://www.newegg.com/Product/Product.aspx?Item=N82E16813130637
But I'm not completely sure if the RAM I also want to buy is compatible with it, which is: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231468
The MOBO says it does support 2133(OC), but I'm kinda new with overclocking (but definitely not new to hardware or computers, I've built many before). So it that RAM compatible? There are many GSkill Ripjaw series that are compatible, all ranging from DDR3 1066-1866. But since RAM is pretty much the same price for all speeds, I want the most for the price. Thanks a lot for any help.
