- Mar 12, 2007
I just got an Asus EEE 900 at target. I think it is the A revision but it doesn't say on the box or anywhere you would expect to have a model number.
$300 - 4GB SSD and 512Mb RAM 8.9" screen
The default OS was craptastic. It worked but I couldn't install much of anything with their package manger. I know Xandros now has CNR for a manager but it was nowhere to be found and the updater that was installed kept saying that an update needs to be installed to fix problems with the updater. When I selected to install it, it gave me an error saying it could not update. So there was a fix for a problem that you needed to download that fixes the problem with downloading the fix ???
Wi-Fi took a horrible amount of time to connect to a new connection but was pretty good about quickly connecting to my normal home network after it got past that first hump.
So anyway I nuked the OS and put Kubuntu 8.10 on it. Word to the wise, make sure your USB drive is formatted to Fat16 or it won't want to boot from it.
Then I followed these instructions with the EEE connected to a wired network connection. http://array.org/ubuntu/setup-intrepid.html After a reboot Wi-Fi works and so does a few EEE specific features.
With Kubuntu installed this thing is usable and I'm very happy with it (boots surprisingly fast too). I even created my own quasi netbook interface with creative use of KDE4's folder view plasmoid (Not my screen shot) with Alt+F12 being used to bring the desktop plasmoids to the front makes for quick launching of apps without using the cumbersome touch pad.
This just sucks that Xandros with its netbook interface is a big Linux representative to the general non techie public. No wonder I keep reading that so many people are returning the Linux models. I bet if they went with Ubuntu then they would not have had so many people asking for Windows.
