- Jun 4, 2012
Hello. I recently installed new 16gb RAM on my Lenovo U410 Ultrabook and my computer gets stuck in a endless windows loading screen. However, it works fine when I switch back to the old memory. The memory gets detected in BIOS as 16 gb and everything posts fine up untill it gets to the windows loading screen
The RAM I bought is G.SKILL 16GB (2 x 8G) DDR3 1600 (PC3 12800)
I used google (like every internet expert should) and found that if I play with the ram speed I should be able to get it to load, but the issue is Lenovo sucks and my BIOS doesn't have the option to change any of the RAM settings (none) or Voltage settings or anything like that.
Do you guys have any other solutions for me?
Edit: So I left my ultrabook trying to boot when I went downstairs and when I came back (30 minutes later) I found that it had booted to desktop. The downside is that everything is crawling (I can't even scroll properly) not running. The processor keeps spiking to 100% randomly and it takes about 2 minutes to open firefox. This IS a fresh windows 7 ultimate install running at 64 bits. I don't get it. CPUZ sais my ram is running at 700mhz (even though the ram is 1600).
Edit 2: I also just tried booting with only 1 8gb stick and it works properly no matter what slot I put it in (or weather or not I switch the sticks out). It seems like they just won't work together. It brings me to believe its a capacity issue (16gb being to much). I know of people who put 16 gb of ram in this model of laptop and it worked fine. Can anyone shed some light on the situation here?
