- Oct 23, 2002
- I don't know why, but...Deleware
you need to set the multiplier somewhere between 10-11.5 usually. On my 8k3a+(nf7-s rev2 on the way) can do 11*210 perfectly stable on my 1700 dlt3c 0319 @ 1.55v.
I don't know what core that 2100 has, but if it is one of the better ones it should be able to go alot higher on that 8rda+. the mobo should top out between 180-230, and usually at the lower end of that range for an unmodded 8rda+ rev1/1.1. You could then do a vdd mod which would make the max usually at 225-240, for what I have seen on air.
good luck with that mobo, I hope you can get a better oc out of it.
huneycutt said:Re'cd the 8RDA+ last evening and installed it and it took off like a champ. The WD HD worked fine with the software for the Intel board on it. Today I tried the Maxor and it can't seem to get the drivers installed for the USB ports on the Epox.
Might be some conflict in software because I had stuff installed on the Maxtor for the computer with the Soltek MB and maybe the EPOX doesn't like that. :-( Just thought I'd give it a try and see what went down.
Thus far the EPOX only OC'ed the Athalon 2100 to a 2700 2.16GHz and seems a bit unstable, locked up and got the blue screen a couple of times but rock steady running it at 2100. I'll play with it some and get it stabalizied. The EPOX has exactly the same BIOS as the Soltek.
If you would please, tell me what setting you use in the BIOS on the EPOX board to push the 2100 to 2700. I'm not that hip to core voltages and all that. All I do is set the fsb to 166 and memory to Auto on the Soltek & its stable but the EPOX locks up using those same settings.
