- May 10, 2009
At a given load, the cascade will remove X watts of heat, the amount of heat removed doesn't change especially.
If the evap temp is colder, less heat is getting to it. So either the wattage of the CPU went down, or the evap isn't getting as much heat from the CPU.
The better the contact and TIM, the warmer the evap temps will be for a given CPU at a given load.
