Gusset Wrench
- Feb 8, 2018
Hi,
I plan to use an EVGA GTX 980 Ti Superclocked AC2+ model under 24/7 intensive load for weeks on end without a break. Will the stock pair of fans be OK or should I replace them with a full cover water block? In the past when running the setup with aother card fitted with stock fan (MSI GTX 580) the card blew up after a few weeks. I think the fan might have packed up first then the card overheated and that was the end of it.
I would be grateful for any advice.
Thx
Gus
Thx
Gus
