- Aug 3, 2004
- Alberta
Hi guys...sorry for the large amount of techy text, but I thought having the specs right in front might be good....just lemme know if I should trim down the amount of specs I dispay for each component for next time.
If y'all could take a boo at this and offer opinions...point out glaring roblems and such, I would greatly appreciate it.
This will be my first build, and in fact I only very recently started boning up on this stuff so Im sure I will make mistakes. Its kind of a first draft, but at this point I think that getting input on what I hve come up with will serve to teach me alot more.
Anyways, here are the peices and specs:
Motherboard
ABIT "AV8" K8T800 Pro Chipset Motherboard for AMD Socket 939 CPU -RETAIL
Specifications:
Supported CPU: AMD Athlon64/Athlon64 FX Processors
Chipset: VIA K8T800 Pro + VT8237
RAM: 4x DIMM for DDR400/333/266 Max 4GB
IDE: 2x ATA 133 up to 4 Devices
Slots: 1x AGP 8X/4X , 5x PCI
Ports: 2xPS/2,1xCOM,1xLPT,SPDIF In/Out,8xUSB2.0(Rear 4),3xIEEE1394(Rear 1),1xLAN,Audio Ports
Onboard Audio: 6-Channel AC97 Codec
Onboard LAN: VIA VT6122 Gigabit Ethernet
Onboard SATA/RAID: 2x Serial ATA, RAID 0/1
Onboard 1394: 3 Ports
Form Factor: ATX more info-> N82E16813127181 $119.85 $119.85
Video Card
POWERCOLOR ATI RADEON 9800XT Video Card, 256MB DDR, 256-bit, DVI/TV-Out, 8X AGP, Model "XR98T-D3" -RETAIL
Specifications:
Chipset/Core Speed: ATI RADEON 9800XT/412MHz
Memory/Effective Speed: 256MB DDR/730MHz
BUS: AGP 1X/2X/4X/8X
Ports: VGA Out(15 Pin D-Sub)+TV-Out(S-Video Out)+DVI connector
Support 3D API: DirectX®9, OpenGL®2.0
Cable/Accessories: 3 Cables, VGA via DVI Adapter, Composite via S-Video Adapter, 5 CD, Manual
Max Resolution@32bit Color: 2048X1536@85Hz
Retail Box (See pics for details) more info-> N82E16814131231 $359.00 $359.00
PSU
Fortron 530W Power Supply, Model "FSP530-60GNA" -RETAIL
Specifications:
Type: ATX
Maximum Power: 530W
PFC: No
Power Good Signal: 100-500ms
Hold-up Time: 16.6ms min.@115V/60Hz;20ms min.@230V/50Hz
Efficiency: Min 65%,Typical 70% (at full load)
Over Voltage Protection: +5V trip point<+6.5V;+3.3V trip point<+4.6V;+12V trip point<+15.5V
Overload Protection: 150% Max
Input Voltage: 115/230VAC
Input Frequency Range: 47Hz-63Hz
Input Current: 12A/7A
Output: +3.3V@30/17A,+5V@44/24A,[email protected],+12V@16/28A,[email protected],+5VSB@2A
MTBF: 100K hours at 25ºC
Approvals: UL, CSA level 6, TUV, NEMKO, FCC, C-TICK, CB, CE more info-> N82E16817104968 $75.00 $75.00
CPU
AMD Athlon 64 3400+, 1MB L2 Cache, 64-bit Processor - Retail
Specifications:
Model: AMD Athlon 64 3400+
Core: ClawHammer
Operating Frequency: 2.2GHz
FSB: Integrated into chip
Cache: L1/64K+64K; L2/1MB
Voltage: 1.5V
Process: 0.13Micron
Socket: Socket 754
Multimedia Instruction: MMX, SSE, SSE2, 3DNOW!, 3DNOW!+
Packaging: Retail Box (Heatsink and Fan included) more info-> N82E16819103426 $305.00 $305.00
RAM -- This one im really not sure of -- dont know if 2x512 is the best choice to go with themotherboard I have selected..could use some help here.
Geil Ultra Series Value Dual Channel 184 Pin 1GB(512MBx2) DDR PC-3200 w/ Blue Heatspreader - Retail
Specifications:
Manufacturer: Geil
Speed: DDR400(PC3200)
Type: 184 Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 2.5 7-4-4
Support Voltage: 2.55V-2.95V
Bandwidth: 3.2GB/s
Organization: two 64M x 64 -Bit
Special Features: Optimized SPD for Dual Channel DDR motherboards
Warranty: Lifetime more info-> N82E16820144310 $191.00 $191.00
HDD -- Trying to decide between this HDD and the one below it. This one is labeled Speceial Edition and is 30 bucks cheaper than the other one, but it is OEM, and im not sure if thats a good thing for a total noob builder...
Western Digital Special Edition 80GB 7200RPM IDE Hard Drive, Model WD800JB, OEM Drive Only
Specifications:
Capacity: 80GB
Average Seek Time: 8.9 ms
Buffer: 8MB
Rotational Speed: 7200 RPM
Interface: IDE ULTRA ATA100
Features: High-performance with 8MB Buffer
Manufacturer Warranty: 3 years
Packaging: OEM Drive Only more info-> N82E16822144122 $63.00 $63.00
HDD -- No Special Edition Here? What are the major differences between this one and the one above? It is retail so that is good ( it means it comes with a manual right?)
Western Digital 80GB 7200RPM IDE Hard Drive, Model WD800JBRTL, Retail
Specifications:
Capacity: 80 GB
Buffer: 8 MB
Rotational Speed: 7,200 RPM
Manufacturer Warranty: 1 year
Packaging: Retail more info-> N82E16822144164 $99.99 $99.99
Sound Card
Creative Labs Sound Blaster Audigy2 ZS Platinum PCI Sound Card, Model "SB0350" -RETAIL
Specifications:
Channels: 7.1
Max Sampling Rate: 192kHz
Signal-Noise Ratio: 108dB
Hardware Decode: Dolby Digital EX
Digital Audio: 24-bit
Hardware Polyphony: 64 Voices
PC Interface: PCI
Connectors: Digital Out for 5.1(6-channel SPDIF Output), Line-Out, Line-In, SB1394/Firewire, Mic-In, Analog/Digital CD Audio In(See Details)
External Box: Yes
Remote Control: Yes
Package Contents: See pics
Special Features: DVD-Audio, THX Certified, DTS-Extended Surround, EAX 4.0 Advanced HD, DirectSound 3D more info->
CD/DVD
Really having trouble with this one -- suggestion warmy welcomed
CASE
Having trouble here as well. Looking for a balance between ease of installation of components(removable MB tray..stuff like that) and esthetics. (Id like a transparent side panel and some nice neon lights) -- Again, suggestions are welcome!
TOTAL: $1378
Well, there you have it, my first attempt at peicing together a system. Please dont hold back and offer any advice you can, cause at this point I think the best way for me to move forward is to get advice on what I came up withon my own...and adjust it accordingly.
Thanks for taking the time to read this post!!
Motherboard
Specifications:
Video Card
Specifications:
PSU
Specifications:
Type: ATX
Maximum Power: 530W
PFC: No
CPU
Specifications:
Core: ClawHammer
Voltage: 1.5V
Process: 0.13Micron
Socket: Socket 754
Specifications:
Manufacturer: Geil
Bandwidth: 3.2GB/s
Specifications:
Capacity: 80GB
Buffer: 8MB
Specifications:
Capacity: 80 GB
Buffer: 8 MB
Sound Card
Specifications:
Channels: 7.1
PC Interface: PCI
External Box: Yes
Remote Control: Yes
CD/DVD
CASE
TOTAL: $1378
