- Sep 10, 2003
- You Should Make a Wish!
the FX-53 s939 is 850-950 bucks, i little to expensive i think, but i you have the dough, by all means get it!
FYI, you don't need to include each part's specs when you list. Generally we can identify popular parts by number, and what we don't recognize is usually easy to look up.
on the case, dont listen to others, Thermalright has some damn fine cases that look good and are easy to work with!
now dont be worried about not knowing anything, we are here to help you every step of the way! and dont worry about OCing right off the bat, Learn about your computer first, and then go OCing!
and dude we wont kill you! well just take your self respecting, money saving soul!!!!! mwahahahaha!!!
After reading that last list, quick question. Are you getting more then 1 of those things of RAM?
Also, does that motherboard require certafied RAM?
and dont worry about having 2 sticks of ram on single channel, all you do is run them in single channel, and yu will be fine!
iseethemtoo said:Thanks for sticking with me for a bit Shard
