- Oct 16, 2002
hey guys.. in a couple months, I think i'm going to be building a watercooling in a couple weeks, so I'm trying to get a list of parts ready. I'd like to make sure that in case I want to add a pelt or two (mainly for the NB and GFX card), or a water chiller, the blocks would be compatible with it. I'm a n00b to watercooling I guess you could say, so I'm not sure if there is such thing as being "pelt ready" or not. I guess I know a little about watercooling, but nothing drastic. I prefer not to make my own blocks yet because I only have a dremel, maybe next school year as I will taking a metal class where we can do whatever we want .
Anyway, here's what I've gathered so far.
Pump: Hydor L30 - $50
Tubing: 10 ft (i reckon this is enough?) ClearFlex or Tygon? $15-25
CPU Block: Coppertop Maze3 AMD - $46
GPU Block: Swiftech MCW50 - $42
NB Block: looking for an alternative to the Z-chipset block, as i don't feel comfortable with a lucite top $40-55
Radiator: '86 Chevette heatercore w/ Comair/Rotron Partiot $30
Fittings: Do i need to buy these? do they come with the blocks?
Resevior: build one myself?
Total: about $250
Also, how would I run this? I was thinking of running it as
Res > Pump > Rad > CPU > GPU > NB
but wouldn't the water be heated up by the time it reaches the NB.. GPU even?
BTW - i realize that to run a pelt, I'd probally need to run another loop because it would heat up the water pretty quickly.
my specs are:
Athlon 2100+ @ 2.4GHz
SLK-800 w/ 50cfm YS Tech
Abit NF7-S Rev1.2.... 206fsb (so NB gets pretty hot)
Sapphire Radeon 9700 Pro w/ Zalman heatpipe cooler
Thanks a lot,
Terro
Total: about $250
my specs are:
Thanks a lot,
Terro
