F@H stats in your sig: not just for Linux anymore!
De nada. Like I said before, Master Yoda Christoph will be back from the wild to show us the ways of the Force Perl. He'll be able to answer any other questions you might have. Have fun with the sig. ;)
Ok i have installed the 2 files but the guide stops after that ? i dont have to add any thing into my Usercp ? I mean it goes from adding it to taskman to Linix install what do i put in my sig config ?
Console,
Which two file did you install? To get a head start on getting a folding sig up and running, you can try the Windows installer here:
http://www.ocforums.com/showthread.php?t=370627
When you think you have a grasp on how to format the signature by hand, you can manually edit the script to make your sig look like however you'd like it to be.
i installed the msi pearl and mksig
i ran the progry it asked for my username and my password ?
then i come back to oc fourms and i dont have any sig let alone my old one =)
the progy you linked is now asking for a EOC ID .... ?
It's all detailed in that post I linked to you. Specifically:
http://www.ocforums.com/showpost.php?p=3506646&postcount=3
Your Name is your folding name, according to Stanford.
EOC ID is your extremeoverclocking.com ID#. If you visit my (JerMe's) user summary page at http://folding.extremeoverclocking.com/user_summary.php?s=&u=5414, you'll notice &u=5414 in the last part of the URL. That is my EOC ID# (5414). You will have to enter your own name and EOC ID# to have the stats work correctly.
So your Name is ||Console||, and your EOC ID is 96365:
http://folding.extremeoverclocking.com/user_summary.php?s=&u=96365
You'd put those two things in there and away you'd go.
Err... not meaning to sound n00bish but I can't find my profile of EOC, I've searched for it but I can't find it. I was wondering if there was a way of doing a sig without the EOC number...
That depends on what system you are running. A P4 would take a few days. Dual core intel's or Quad core's a day.
Whats you're user name and I'll figure it out.:)
Sorry to bump such an old thread but the download link is dead - should be edited :)
