- Jun 20, 2001
- Vancouver, WA
- Thread Starter
- #21
New version is up!
This version should fix the problem some of you have had with RPC not working. I haven't had many guinea pigs, but it appears to work now.
Quick and dirty changelog:
JigPu
- Fixed "Fix program to correctly get $result_project[][]" bug
- Modified the portion of code which creates $project so that only one project is displayed (since BOINC only runs one project at a time)
- Set the length of progbar percents to be 3 chars so that things are properly aligned
- BoincStats modified layout yet again, SETI RAC, BOINC overall rank, and BOINC total credit now fixed
- Included display of progress according to what is recieved form $boinc_usefile (if enabled)
- Included logging of recieved XML to the files BOINC.xml and BOINCmodified.xml, containing straight-from-boinc and modifed-for-script versions of the XML respectively.
- Hopeful layout fix for if/when a dual CPU machine only is running one result
- Included a new layout function setWidthRight which acts as a "right-align" version of setWidth
- Using the new setWidthRight I should have fixed a few layout problems for SETI/General stats
- Added "PST" to the time printed out
- HOPEFULLY fixed problem of RPC clients not sending full XML...
- Included "No Work" indicator when a machine has no running results
JigPu
