- Dec 19, 2012
I saw one person say that he did not consider his system stable unless it could run P95 and Furmark at the same time without issue...
For people using software like F@H and my Bluray software even Seti that uses every bit of processing power from the CPU and the GPU's. This would give them a good idea of overall temps and driver issues.
Originally Posted by Mandrake4565
As you well know overclocking is all about learning, a lot of people don't want to learn, they just want to come here and find numbers to plug into their system and viola they have an overclocked pc. You know as well as I do that it doesn't work that way. The ones who come here that want to learn and understand the inns and outs of overclocking will learn what their system needs to be stable for their uses. Some will find prime overkill some will find it a necessity.
What these folks forget, is variety, the spice of life, the simple point that not everyone who overclocks requires the same treatment. Not every user is running F@H 24/7. Not every user is a hard core gamer playing Crysis 3 for hours on end. Not everyone is using a PC in a resource intensive way and many of them will never, ever peg all CPU cores and subsystems for 2 hours straight. In reality, many users will never need the stability that prime95 demands.
So do these people need to OC their system or just want to for the sake of " My machine runs at 6.5GHZ" and all the power to them.
Personally I don't care either way if the individual does or doesn't run prime for 2 hours and if their machine blows a cap at some point it's all their problem not mine.
I ask people to run prime so that in the event they may actually be working their system they don't have some catastrophic failure solely because their OC was too high and they had a melt down.
