- Jan 26, 2017
so i have a thermaltakeThermaltake Pacific DIY LCS PR22-D5 300ml 5-Speed Adjustable D5 Pump/Reservoir Combo 3-Port G 1/4" Thread Tt LCS Certified POM PMMA CL-W082-PL00BL-A pump,a heatkiller iv pro nickel waterblock and an ek coolstream ex radiator, this pump keeps failing, this is a repclacement pump. the first one i bout lasted me about 8 months and i had to rma it and this pump is about 4 months old. it has really bad vibrations at the motor and the pump will eventually start knocking against the pump housing and eventually freeze up. should i go with a different pump? is this pump not suffcient for the radiotor and waterblock im using. im stumped i have no idea why this particular pump keeps failing. i have the same pump on my gpu loop but it does fail and has much less vibrations at the base where the motor is. any thoughts would be aprecaited, i cant figure this one out. thinking about just scrapping teh whole loop and donig a new one
