R RoninX91 Registered Joined Aug 15, 2012 Sep 8, 2012 #1 My new upcoming build is the first time I am using fan controllers, does 6 channels mean you can control only 6 fans or can I control more?
Knufire Senior Member Joined Feb 17, 2010 Location Manassas, VA Sep 8, 2012 #2 You need 3 pin splitters to control more than 6 fans. Make sure you don't exceed the maximum wattage per channel. http://www.frozencpu.com/products/1090/cab-05/3-pin_Y_Cable_Splitter.html
