hello
the fans i bought didnt come with 3pin 4 pin adapters
since there are no solid built/12v giving 3 pin 4pin adapters found in my country so the fan controller i bought for my new buid is kind of useless (only 5v ones which aren't enough for 12cm fans,plus they are flimsy)
im looking for a fan controller that has
_preferably 6 channels (i have 6 fans and my mobo doesn't have pwm slots other than cpu fan and that is obviously occupied by the cpu fan)
_pwm connection (as mentioned i dont have access to working adapters)
_preferably fitting 1 5.25 slot (i dont have any more room on the front of my case,if its 2 slots i can remove the dvd drive tho)
i can buy 2 controllers if the arent 6 channel ones
