- Aug 11, 2003
- Los Angeles, CA
- Thread Starter
- #21
Woohoo, I lapped my first heatsink.
This is what it looked like beforehand. I used 800 grit on it at first, then went to the 1500.
After a nice finishing with the 1500 grit paper, I realized that there was an indentation in the center, where the processor core would sit (which you can kinda see here - it's the rougher part of the reflection, where the original machining marks still existed). So the heatsink wasn't completely flat! I had to start over again with 220 grit paper to flatten it out, then I went back to the 800 and 1500. Afterwards, I really wanted a mirror finish, so I took out the most common household polishing compound - toothpaste.
I polished it with my dremel and buffing wheel, then gave it a warm bath in the sink. I let it drip-dry, then reinstalled it with a fresh coat of the only batch of grease I've ever owned - a small amount of the original Arctic Silver. I moved the hard drives into the upper 3.5" cage and took out the lower one. I think my temperature dropped, but I can't be sure: I was using a 5.25" temperature monitor, and to lap the heatsink I had to remove then replace the probe. I'm getting temps 2-3C higher than before, but the BIOS is now reporting lower than before. I think this one worked a little.
Uh oh, at 1% battery power, have to post and run!
