- Oct 14, 2006
- Clemson, SC
HeavyD said:I have a full aluminum case, any problems/issues with cutting or drilling this material?
y friend often finds ways of breaking my fans. its annoying as anything. he's broken like 3 fans
i now have fan grills on fans inside of my case because of him
Depending on the fan's speed and how it's stopped it isn't all that difficult to snap one of the blades off--I've done it more than once testing fans before use.trodas said:Technical question. How one can broke a fan?
Call me stupid, but even if you stop the fan, nothing bad happens? (maybe after a long time it can overheat and the coild inside burn, but that would took very long)
Well, I broke a Delta and a Sanyo Denki so I don't think blade quality was the issue. I think it's just a question of if the fan "hits just right" ...trodas said:MVC - hmmm, I'm probably too carefull that it never happened to me - yet. Or maybe I did use only fan's with too tough blades?
The ones I got from BestByte were slightly raised on the ends. Mounted, like in your pic, they'd end up being flat (more or less) with the outside of the case.trodas said:Anyway, regarding to the http://www.bestbyteinc.com fan grills - did you order from them sometimes? I looking for simple a grills that did not have their end's bend - eg. the whole grill are flat, like this one:
http://ax2.old-cans.com/s.php?p=wc&id=67&c=8&d=1&v=v2
(if the end's is not flat, then the grill is not possible screw to the case this way... I take these from Enermax PSUs, in case you wonder why I looking for them, when I have few of them already... )
Well, here in NYC, I don't think I've seen any type of grill in a store for less than $2.50 and they're usually more, so.... If you only need a few and can find them at a good price locally then that's the way to go. With online retailers the shipping can sometimes be the deal-breaker, and with low cost items like this it's easy for shipping to be several times the cost of the items being bought.HeavyD said:Thanks MVC. I wonder if MicroCenter has some grills? I'll have to do some comparison shopping at the Denver store - it's a dirty job, but someone has to do it.
It was the tip of a finger with the Delta (I didn't need any stitches, but I did consider it ) and the edge of the table with the Sanyo Denki, the fan started sliding and I DID NOT try to catch it--the table survived. And, yes, both fans were at full speed.trodas said:MVC - ugh. And may I ask, what you stuck into the rotating fan, presumably at full speed that this happend?
Because on the 92mm ones the "slight raise" is way bigger and make the way I like to add them impossible and the result is just plain ughly...
(let's hope the images works well)
