- Thread Starter
- #21
remounted, added a tad bit more Arctic Silver as I noticed that 1/5th of the heat sink left a mark in the paste on the die. Made sure I had perfect contact.
Switched my fans all on high (sounds like a freaking vacuum now) and still hitting 100c after just 3ish minutes of running prime.
Going to bed for now. I've got 3 co-workers who also have the i7 and a demo computer with it. Going go see if those systems are getting the same temp readings. If they are we've got an issue to solve. =D
I'll get the true and see how that effects things. I'd like to get the copper one. Don't know a lot bout cooling, but I do know that copper is better than steel/aluminum when it comes to heat transfer.
Thanks for your input =) if you've got any other tricks to suggest i'd GLADLY try them =D
