- Oct 6, 2005
- Fayetteville N.C.
Settled on this: http://www.thermalright.com/new_a_page/product_page/cpu/u120ex-775rt/product_cpu_cooler_775rt.html
You did get the 1366 Hold down kit for it right?
which i spread around a bit with a plastic bag.
I did indeed.
do not do this!!!!
the heatsink will do the spreading, go top AS website and see the proper document for placing your AS5 on the CPU
also take that rear fan and have it blow out, your likely sucking in hot air from your PSU onto the CPU
in fact the rear and toip i would all having blowing air OUT
if all your i7 builds are running hot, i would be more likely to look at user error putting them together.
you keep saying you are not overclocking, but your scn shot clearly shows 159 bclk. Unless I am completely and uterly wrong, speed step only decreases speed and turbo only changes the multiplier when not loading all 4 cores. In which case you are doing something to overclock your cpu manually. I believe evga has a "dummy overclock" setting which sets the blck to 159. Check to make sure this is off and what your temps are like with it off.
gonna have to call bull**** on that. A 1.3Ghz oc from turbo mode with stock settings? Intels own specs will tell you that is not even possible. Sure, I'm running 4.0 with HyperThreading and Turbo on but it requires increased BCLK's. It cannot be done on a 920 without changing your baseclocks...period.neither. The chip auto clocks. Can reach 4ghz without touching it if its kept cool enough.
I've not manually over clocked it. i've got 2 of the 3 at work running at 3.1-3.4 ghz by only enabling intell speedstep. I'm thinking I may have a bad temp sensor. when I get home im going to check it in bios. Just wish I could stress test it from bios. It also just occurred to me that the mount and the board around the chip doesn't get hot. When i take the chip out (takes about 5 minutes from shut down to in my hand) its only luke warm.
I know it does look as if I've manually overclocked it, I've had it for about a month now. It is my understanding, and I believe I am correct, that the i7 chip can both under clock itself, and over clock itself provided that certain criteria are met.
http://www.intel.com/technology/turboboost/index.htm?iid=processors_rhc+pt_turboboost
Speedstep allows the proc to down clock, turboboost allows it to up clock.
Both of these are enabled on my system. Dummy OC is disabled (if its enabled you will not be able to use SS or TB)
there are two machines here at work that are similar to my own, and one that is Identical right down to the batch#s and S/Ns they would have been made, and shipped on the same day from intel/evga/patriot etc.
One of these two that are similar is currently clocking itself between 3.00. and 3.51 ghz. If I run prime 95 on it and it gets above 101c it drops its clock down untill the temp goes to 100c or cooler.
The one that is the same as mine will clock to 3.4 but never more. Usually sits right around 3.2. Same story though, at 100% its always at 100c. idle its around 60c.
Yerp the fan is indeed spinning. I added about a grain of rice size of paste on the cpu, which i spread around a bit with a plastic bag. Wiped the remainder off on the sink, it coated the die with about half a mm.
I recall seeing him answer it in his other thread. Some utility had OC'd his system. After he reset his bios it was back to 133BCLK. So he did solve that mystery and turned off the software that did it. I don't recall if he answered whether it was still too hot or not and if he was still going to get something aftermarket for cooling.
MAy sound stupid but, why do you place your top fan on inhale , hot air rises so it's best to set that one to exhaust and the bottom one to inhale
