- Dec 12, 2011
- Clarksville, Indiana
I'm using 2 Scythe Ultra Kase fans in a push pull on a CM Hyper 212 Evo and i was wanting to try to control both of them from a fan controler but on the same channel so the rpms will be the same on both fans. I use a 4 channel fan controller in one of my 3.5 in. bays and all the other channels are full atm. What would i need to do this. Do they make a splitter or adapter i can buy for both fans to run off 1 channel or would that pull too much voltage??? I was wanting them to be like PWM fans if possible and maybe run them from my mobo. Any ideas are helpful, thanks in advance
