- Mar 13, 2011
- Chaparral, New Mexico
Ok 2 questions...
-When doing a push/pull configuration on a rad, does using 2 high static pressure fans benefit over using say ap15's push and another fan for pull?
If it does make a differnece then ill just get all ap15's, if it doesnt make a huge difference though.
-Id like to use led fans as pull, as they will be facing the exterior of my case against the mesh. So a little eye candy. But looking for something quiet.
I have Cooler Master R4's right now and well they were never loud tell I got my ap15's.
So if i want ap15's for all then ill stick with that. If not, reccomendations on a quiet led fan to use as a pull.
